08-23-2021 09:19 AM
I need to add option 156 to DHCP on my RV340 router but I don't see it listed under DHCP Options. Can this option be added?
Solved! Go to Solution.
08-24-2021 02:44 PM
NO You cannot. What options you see listed are what is available and supported. Its a closed GUI-config on the Router
08-24-2021 02:44 PM
08-25-2021 05:25 AM
Understood. Thank you for your reply, I just wanted to do my due diligence to make sure it was not an option.
