RV 340 setting up DHCP Option 156
I need to add option 156 to DHCP on my RV340 router but I don't see it listed under DHCP Options.  Can this option be added?Capture.PNG
nagrajk1969
NO You cannot. What options you see listed are what is available and supported. Its a closed GUI-config on the Router
nagrajk1969
Understood.  Thank you for your reply, I just wanted to do my due diligence to make sure it was not an option.
