RV 340 - Valid ip configuration error in devices
chiragmittal2
The following us the configuration of my wifi system. As an input I use two providers: Airtel on WAN 1 (IP address 192.168.1.30, Default Gateway 192.168.1.1, DNS 192.168.1.1) and Tata on WAN 2 (IP address 192.168.1.22, Default Gateway 192.168.1.254, DNS 192.168.1.254). The multi WAN settings are set 50/50 for load balance. The output from RV340 goes into a Linksys Velop mesh system.
The problem I am facing is that many of the devices on the wifi network are not able to connect to internet. The error that is shown in the laptop is 'Doesn't Have A Valid IP Configuration'. I have rebooted the entire system multiple time but the error is not resolved.
marce1000
   - How is DHCP configured ?
 M.
balaji.bandi
The IP address space RFC 1918? is this masked here to post the community, or is the one you get from the provider ?
On the Lan side - what is the IP address range you getting for LAN, what is the IP address range for Wireless ?
you may need to static routing towards Linksys for the Lan side IP address (this is just a guess based on the information).
From client can you able to ping gateway, RV LAN side IP address ? can you able to ping 8.8.8.8 ?
try setup DNS 8.8.8.8 and check
BB
