RV 345 BUG on Multi-WAN Precedence
StanislawSB
Hi!
Cisco SB RV345
Firmware Version: 1.0.03.29
There is a bug on Precedence. If I change the order with precedence
WAN21
WAN12
USB13
USB24
The router continues to use WAN1 ethernet for ALL VLANs
Try with WAN1 & WAN2 enabled/disabled "Network Service Detection"
If I put on WAN1 IP with no ping reply, the router will switch the internet to WAN2.
But when I put normal IP to internet service detection, the internet goes on WAN1 again.
What's the problem? Why do I get internet over WAN1, not with WAN2?
5 Replies 5
balaji.bandi
if you looking for weighted preference you need to set high which one to use. as mentioned below link. ( also try to upgrade latest firmware on your device, look old I guess)
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/KMGMT-1568_WAN_Load_balancing_on_RV340_Router.html
BB
as per the screenshot you have selected weighted preference with dual wan.
BB
Are you looking active/standby ( active/active )
if you looking Active/Standby
you set WAN2 preference, and WAN1 lower preference, have you changed this config on fly? check to reboot the device and test it.
BB
