03-29-2021 10:45 AM
Hi I'm new to the RV-345s, I have an RV-345P which should have PoE on ports 1-4 and 9-12, but when I go tot he PoE config I have no ports available to edit.
I'm running firmware 1.0.3.20 and it looks just like in this emulator
How do I get the ports to show up so I can enable PoE on the switch? Also why don't they show up in the emulator?
Also nothing on the PoE settings page will save, if I switch it to Class Limit and save it reloads and it's back to Port Limit. So seems like PoE isn't working at all.
Included a SS of what I see though it's the same as the emulator.
Thanks in advance for any help
Solved! Go to Solution.
03-29-2021 01:59 PM
After days for reading the JS and xml config I found the issue, my config was missing a block in interfaces->interface
<poe-setting xmlns="http://cisco.com/ns/ciscosb/poe"> <enable>true</enable> <administration-power-allocation>30000</administration-power-allocation> <priority-level>low</priority-level> </poe-setting>
need to do that for LAN 1-4 and LAN 9-12
Why the JS doesn't fill it in is beyond me, but for anyone else with this issue this is the fix.
03-29-2021 01:56 PM
03-29-2021 01:59 PM
