I'm having issues with the wan IP and PPPOE, first when I use PPPOE the gateway never gets the static IP the ISP centuryLink sets. Nothing else can be done is what centurylink responded today.
The second issues is I go in and change the modem to USE PPPOE and than I setup the one to one nat and enable it, I was not able to successfully map an external IP to and internal IP successfully other than the wan IP was working with port forwarding.
Any help would be appreciated, I have hours of my time into this.
