07-27-2013 12:03 AM
In the admin guide of this series, at Configure Network > WAN settings > Mobile network setup, it says:
"The device automatically detects supported modems and lists the appropriate configuration parameters. The SIM PIN can be modifed in either Auto or Manual mode.
The Card Model shows the model of the modem in the USB port. Unsupported cards are reported as unrecognized."
So, is there an official reference to what are the supported cards and what's not?
I am buying this router, and I want to make sure it works with my 3G USB dongle. I live in Vietnam, BTW. Please help
Solved! Go to Solution.
07-28-2013 10:08 PM
Hello Tan,
Here is the list of all the supported modems:
https://supportforums.cisco.com/docs/DOC-30229
Unfortunately, I don't see Vietnam in the above list. I suggest calling the Cisco support in your country and choosing a locally available modem that is compatible with both your Cisco equipment and desired ISP.
Hope this helps,
Vijay
Please rate useful posts.
07-28-2013 10:08 PM
Hello Tan,
Hope this helps,
Vijay
08-01-2013 03:43 AM
Thanks a lot
Your information is very helpful
