01-15-2020 03:54 AM
I have a problem accesing my rv042 admin interface. There is only a menu. No options are accessible. I have tried Internet Explorer, Firefox and Chrome.
01-16-2020 01:41 AM
Hi Markus,
My name is Puneet Sandel and I am from technical support team for small business devices.
Please confirm whether you tried using a different browser (except IE). Also do you face any latency pr ping drop when you try to ping the default gateway of the RV042.
Puneet Sandel
Technical Consulting Engineer-Level 2
Global CX Centers – Small Business Support
01-16-2020 06:37 AM
As mentioned previously I have tried three different browsers (IE, Firefox, Chrome).
There is no latency pinging the gateway.
01-27-2020 09:02 PM
Hi Markus,
Please confirm whether you tried clearing cache memory of the browsers. In case the issue still persists, please get a new case open with Cisco and we will definitely help you out with the same.
Have you tried doing a hard reset on the device too? If not then I advise you to do it once and check for the issue before opening a case with us.
Puneet Sandel
