RV042 Gateway to Gateway tunnels not reconnecting
soportemosi
I have two Cisco RV042 Routers, they are being used to connect two offices, i have created a standard gateway to gateway connection, fixed public ip addresses on both sides and everything works fine, except when the tunnel gets disconnected, it does not connect back automatically, i have to log into either  router console and click the connect button to get the tunnel working again, this is really annoying since it happens once or twice a day at least.
I would think the router should do this automatically, reconnecting whenever what was wrong gets fixed. i.e. internet connetion is back up
Thank you very much for your help
Te-Kai Liu
Level 7
Level 7
Do you have DPD and Keep Alive enabled on both ends of the tunnel?
Thank you very much for taking the time to answer my question, i cannot believe i had left out the keep alive parameter.
For sure thats  whats wrong in my configuration. That should solve the problem, such a rookie mistake.
Again thank you for your answer.
