rv042 load balancing - dropping gtalk
tuntunlin
i've 2 adsl lines (1Mbps download speed and 512Kbps upload speed) and used rv042 for load balancing.
but sometimes, IM program like gtalks don't work well.sign out and sign in again and again
i adjusted MTU sizes (1500, 1490, 1492, 1480) and still have problem
12 Replies 12
Alejandro Gallego
Try this:
Required ports to use Google Talk
Print
If you're having trouble connecting to Google Talk through your firewall or proxy, it may be because some necessary ports are blocked.
In order to connect to Google Talk and start sending IMs, you'll need to enable TCP connections to talk.google.com on port 5222, or on port 443.
If you'd like to make calls or transfer files through Google Talk, you need to:
  • Enable UDP connections to anywhere on any port; or
  • Enable TCP connections to anywhere on port 443.
If you're behind a public or corporate network that is blocking these ports or protocols, please contact your local network administrator for further instructions.
From Google Q&A
thanks for you kindly reply
not blocking port error. when i remove linksys rv042 and use with isa server, it is ok.
my network configuration is the followings
two adsl modems => linksys rv042 => isa server => local client computers
my problem is not blocking gtalk, it can easily connect gtalk server and sign in within 5 seconds.
but, within one hours, sign out and in again and again (three to five times).
pls advise me.
thanks in advance
You could try to use RV042's Protocol Binding to bind the traffic destined to gtalk server to one WAN port.
yes. i've already set protocol binding rules like that.
HTTPS [TCP/443~443] ->192.168.10.2~2 [0.0.0.0~0.0.0.0]/WAN1
HTTPS Secondary [TCP/8443~8443] ->192.168.10.2~2 [0.0.0.0~0.0.0.0]/WAN1
So you mean you are logged in and happy google tallking and then after about an hour the application logs out and then auto-logs back in?
Have you looked at the logs on the ISA server? I am not completely familiar with the back end of Gtalk so not sure if there is an IP change (re-direction) or if there are time-out values, but it alsmost seems like authentication is happening at one location (IP or Port) and talking else where (IP or Port). Maybe you missed something in the ISA after installing the new router???
That is very intersting behavior and will be tough narrowing this down. If possible, doing some packet capture between the RV and the ISA would be very helpful.
hi  mr. alegalle
thanks for your disscussion.
i think this is not isa problem coz problem still occur when i directly connect rv042 lan port.
pls advise me.
jamccord
What happens when you only have one WAN connection enabled.  Do you still drop going thru the RV042 or will gtalk remain connected?  Does the application disconnect when you add the second WAN?  Please test and let me know the results.
yes
when i removed WAN2 plug and i changed nothing in router configuration, it work fine.
is this load balancing problem ?
i found that gtalk connect google server with https:443.
i dont' let go https traffic to wan2 with this rules in protocol binding
jamccord
Please confirm the version of firmware applied to the router. Current version is 1.3.12.19-tm.
yes. my firmware is that version
Serial Number :                     AHY08HC01533
Firmware version :                     1.3.12.19-tm  (Feb 13 2009 13:03:21)
CPU :                     Intel IXP425-266DRAM :                     32M
pls advice me
i've no idea for that
tuntunlin
hi everyone
pls ..
who can help me ?
