RV042 Login page not showing
Shahbaazsaifee
Dear Support Team,
RV042 pinging fine with default gateway 192.168.1.1,but login page not showing and use many diffrent browsers use,
orange light DIAG light blink again and again and reset also.
pls suggest...........
balaji.bandi
check the symptoms :
DIAG — If the LED lights up and is steady, the router prepares for usage. If the light flashes slowly, the router is powered on, resets to factory default or upgrades its firmware. If the light flashes quickly, there is an error. If the light does not light up, the router is ready for usage.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb696-status-light-and-port-functionalities-on-rv016-rv042-rv042g.html
I will remove all the cables isolate the router and do another factory reset. (until you have setup and GUI access, do not connect any other cables).
BB
1- my router is pinging with 192.168.1.1 but login page no showing
2- DMZ mode green light on
3- DIAG light orange blink after every 7 seconds
pls suggest solution
