RV042 please help how to direct traffic through specific wan port?
John Clausen
I have an RV042. I understand and have created the services I need. The documentation is just not clear on how to direct traffic for these services to a specific wan port.
Can this even be done with this router? If so, the how? Use rate control or priority? Does checking a wan port mean that it will only go through that port?
Thank you,
John
Te-Kai Liu
Level 7
Level 7
You could bind service along with IP range to a given WAN interface at System Management>Dual WAN under the Protocol Binding section.
On our RV042 (3) FW 4.2.1 this menu does not appear...
no matter if SmartLink oder LoadBalance is selected.
Click on the "Configure" icon to see the settings.
Uuh..stupid question
Thanks!
