RV042 Port Nating
mccisales
Hi:
I have an SMTP Server that sends emails out on port 25.
I want to send this to the google mail router SSL.  Google accepts this on port 465.
I need to send emails out from an internal IP Address 192.168.95.1 port 25 then on to smtp.gmail.com on port 465
Will the RV042 do this (I am using the new CISCO RV042.
Thanks!
Hello Mr. Mason,
Welcome to the Small business support comunity.
Let me share with you some information related to the NAT configuration on a RV042, found on the guide me setion where you could find all the information related with Cisco Small businness products configuration.
http://is6.nohold.net/CiscoSB/ukp.aspx?vw=1&docid=e3105749e13f40a3a302802259189e07_Setting_Port_Range_Forwarding_for_the_RV042.xml&pid=4&fcid=&fpid=&slnid=18
http://is6.nohold.net/CiscoSB/ukp.aspx?vw=1&docid=2134697b1d7844cfa16a300fb0762cd2_Setting_Port_Triggering_for_the_RV082.xml&pid=4&fcid=&fpid=&slnid=18
hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Diego Rodriguez
Cisco network engineer
Thank you
Te-Kai Liu
Level 7
Level 7
The current RV042 firmware does not support sending email logs over SSL.
