RV042 with Dual Internet with Primary\Backup Setting
Adam44992
We currently have a RV042 v3 with two Internet Connections. T1 and DSL. We are setup to use the Primary WAN 1 (DSL) and Backup WAN 2 (T1),  However I want a internal device to be able to only use the Backup WAN such as for RDP for remote access. Is this possible?
Also if this is done using One to One NAT, can I have a NAT statement for a mapping to an external IP Address for each Internet circuit?
Adam44992
Just adding more info:
If I select the Load Balancing mode, I am able to have two NATs to the same internal host. NAT to two seperate external IP Address, provided by each carrier. Can this still be done when Primary\Backup Internet is selected? I guess use inbound access on either circuit, while outbound internet will only use Primary, unless it fails to Backup.
thx
Adam
