rv042 won't logon
fmclemore1
My RV042 router refuses logon to its url. The router works with the default settings but won't allow access to its setup pages.  The default IP pings OK 192.168.1.1.  When a browser attempts to connect to 192.168.1.1 , the browser responds with "SSL received a weak ephemeral Diffie-Hellman key in server Key Exchange handshake message." ( Error code: ssl_error_weak_server_ephemeral_dh_key).  Resetting to factory defaults has no effect.
ruwyatt
HI,
Which browser are you using? Try using Chrome or IE or see the below link regarding Firefox.
https://support.mozilla.org/en-US/questions/1066238
Make sure to update to the latest firmware version of the RV042. Link is below..
https://software.cisco.com/download/release.html?mdfid=282414010&softwareid=282465789&release=4.2.3.06&relind=AVAILABLE&rellifecycle=&reltype=latest
.:|:.:|:. CISCO | Russ Wyatt | Network Engineer | Cisco Technical Support |
Thanks for the quick response.  I have tried Chrome, same result.  I have another RV042 that I am now using and have no trouble logging to it.
You suggested updating the firmware. How do I do that if I cannot login to the device?
MdChowdhury
I have been trying to login my router from web browser. it does not allow me to login and give an error about protocol. Please advise.
