RV042G client to gateway connection - interrupted action
adrianvasiu
Hello
Have an RV042G (firmware 4.2.3.14); set up client to gateway connection using Shrew Soft .
I am able to connect without issues ... except when I try to copy files in Windows Explorer (through a mapped drive).
The file transfer starts but around 40% I get "Interrupted action"
Error 0x8007003B: An Unexpected network error occured
and the file transfer never completes.
changed MTU, Support IP Payload Compression but no improvements.
Can anyone help please?
balaji.bandi
I do not believe this is from VPN side, more of Look source and destination has any Antivirus enabled, or any connectivity issue.
how big is the files, try copy different Server or client and check ?
BB
marce1000
 - Check this thread : https://community.cisco.com/t5/small-business-routers/rv180-vpn-file-transfer-failure/td-p/2675904
 M.
Hello
First of all, thank you all for your comments.
Here are the additional details:
  • OS: Windows 10 x64
  • File size: 5 MB (smaller size files can be transferred correctly)
  • even if Antivirus is turned off - no behavioral changes
  1. The SMB solution did not work for me - tried to force to SMB1 but same result. https://techcommunity.microsoft.com/t5/storage-at-microsoft/stop-using-smb1/ba-p/425858
  2. The 0x8007003B solution - does not apply here - I have Windows 10 64 bit
