el 01-03-2017 01:31 PM
RV042G using dual wan
and would like to open a port# (eg.1234) on WAN2
set Firewall->Access Rules-> Action=Allow, Service=Port#1234, Interface=WAN2, Source=Any, Destination=device IP, Time=Always
set Setup->Forwarding-> port1234[tcp/1234~1234]->device pc [enable]
however when I test the port, it always bind on WAN1 IP
is there any way to fix this...
¡Resuelto! Ir a solución.
el 01-05-2017 03:50 PM
I have configure my router with same rule and works, what version you use and if there's other settings?
el 01-05-2017 12:03 AM
Hi, since forwarding rules is mapping to all of ports, you have to add one more rule to deny traffic from wan1, and I'm not sure what you mean "bind on wan1 IP"?
Access Rules->
Action=Deny, Service=Port#1234, Interface=WAN1, Source=Any, Destination=device IP, Time=Always
el 01-05-2017 07:18 AM
I'm using load balance
after open this rule "set Setup->Forwarding-> port1234[tcp/1234~1234]->device pc [enable]"
we can connect this port with WAN1 network and its working, but I want it to use on WAN2 network only
follow your step to deny this port on WAN1, WAN1 deny but WAN2 still not open...
el 01-06-2017 10:21 AM
I have VOIP system running on WAN1, the other just normal port forward on WAN1
and i did make sure WAN2 port forward is ok problem if i am not using dual WAN router
el 01-08-2017 09:30 PM
Up to now, I think the only possible reason is wan2 NSD fail to remove the connection? Maybe u could try to disable wan2 NSD and see how it goes.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
