RV042G Firmware Failure
paulthiem
Firmware failure on the rv042g router. I am unable to access the web interface, and holding down the reset button appears to do nothing, (unplugging holding the reset down and plugging it back in while still holding the reset until the lights flicker and i even tried for a min plus) DIAG light is still blinking.
I am able to still ping it the router though.
I downloaded the firmware upgrade utility and tried that with no success. The ip is set to the default but the default password isn't working, neither is the password that was set in a working condition.
i appreciate any help!
jeffrrod
Level 4
Level 4
Dear Paul,
Thank you for reaching Small Business Support Community.
If the Diag status light continues to flash, the firmware image is damaged.
Please try out the Firmware Rescue Utility v4.0.0.7;
http://software.cisco.com/download/release.html?mdfid=282414010&softwareid=282465800&release=4.0.0.7&relind=AVAILABLE&rellifecycle=&reltype=latest
If you have any problem and/or require further assistance about this firmware failure, I suggest you to contact the Small Business Support Center;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything I may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
