Usually, a simple acces rule in a Cisco firewall, doesn't lead to any major connection issues, however a customer wanted the small business router RV080, running a replica server on the inside, which require some connections to a few servers on the outside.
I wanted to limit the access to a LAN address from a single WAN address, an example of a NTP connection:
Enable <V> - Action <Allow> - Service <NTP(123)> - Source Interface <WAN1> - Source <91.*.*.*> - Destination <192.*.*.*> - Time <Always>
But in this test (as in any access rule for different services), the client on the WAN side cannot contact the host on the LAN side, the only way I could get it to work, was to set up a Port Range Forwarding (Setup - Forwarding).
Now it works, with or without any Access Rule - alright, but the down side is that any IP on the WAN is able to contact the LAN address, at the specific port/service, not limitting to the specific WAN address above.
Anyone got some comments/tricks/solution for this?
Mike
