RV082 DNS Local Database doesn't work
I recently upgraded the firmware to 2.0.2.01-tm (from 2.0.0.19-tm). Now I noticed the RV082's local DNS server ("DNS Local Database" feature) does not work any more. Any URL-IPaddr combo I used to put in there was resolved prior to sending a request to the WAN's primary/secondary DNS server.
It isn't a PC problem. I tested on different real and virtual machines, windows and Linux. Is there new "enable" switch somwhere? Anyone, any ideas? Suppose I log into the RV082 with puTTY, what can or should I do?
jasbryan
Level 6
Level 6
Andreas,
Have you deleted your entry's and re-added them?
Jasbryan
I was afraid someone was going to suggest that... No, but I would consider it. To add them back, is there a puTTY way to do bulk / mass inserts?
How about doing a reset and reloading the config backup from just before the upgrade?
You can try a factory reset and reload the configuration but the above step i suggested if it didn't work then next suggestion would to be factory reset and reconfigure manually and then test.
So yes you can try that first then try what i suggested and if that don't work then it will be next step
Factory reset and reconfigure manually.. Some times when upgrading it can cause some corrupted files and only way to fix is a factory reset and reconfigure (manually)..
Jasbryan
