rv082 login problem
heddebaut
I can connet via the web interface without problem.
If I disconnect and try to connect log in again, I can access the login page, but when I submit it, it freezes.
I have to reboot the router to recover
Has anyone the same problem, and maybe a solution to it
regards
jean-yves
for info: browser is safari, but same problem with firefox
jonatrod
Level 7
Level 7
Good morning jean-yves.
Thanks for using our forum.
You can try with other browser, it could be internet explorer, opera or google chrome, also try resetting your device, also check your firmware version, the  latest version is 4.2.1.02 you can download it  in this webpage:
http://www.cisco.com/cisco/software/release.html?mdfid=282414011&flowid=785&softwareid=282465789&release=4.2.1.02&relind=AVAILABLE&rellifecycle=&reltype=latest
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered and rate the correct answer.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
jonatrod
Level 7
Level 7
Greetings,
Johnnatan,
thank you very much for your answer.
In the mean time, I made a factory reset and it solved my problem
thanks anyway
regards
jy
