Good morning.
Thanks for using our forum.
Hi Zeeshan Ali my name is Johnnatan and I am part of the Small business Support community.
In order to resolve your problem , you can follow these two tips:
Step1: Go Firewall > Access rules and check that there is a rule that is blocking any port or some ip address which prevent the Ping or remote access.
Step 2 : Go Firewall > General and disable the āBlock Wan Requestā and enable the āRemote managementā (also you can change this port).
I hope you find this answer useful, if it was satisfactory for you, please mark the question as Answered.
Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
āPlease rate useful posts so other users can benefit from itā
Greetings,
Cisco Network Support Engineer.
