11-24-2012 02:30 AM
Good day,
currently I experience some connectivity problems on a RV082. The latest Firmware is installed (no V3 unfortunately).
Currently the router is pingable and also Port 80 and 8080 are open but they do not respond to any http request. Routing functionality is also not working. Unfortunately also after a power cycle nothing has changed.
Boris
11-24-2012 01:49 PM
Hi Fredrik, is the router providing the DHCP services? Is there any changes if you provide a static IP on your computer? Are you connecting directly to the router or through other network equipment? Can you try to connect to all 8 LAN ports and check for connectivity? Are you able to reset the router (hold reset button for 30 second or so)?
-Tom
Please rate helpful posts
12-03-2012 01:17 AM
Hi!
Yes the IP is static, connection through a managed switch but its also not working with a direct connection. Router is now, after a factory reset, still not reachable.
