10-31-2013 02:39 PM
Hello!! i have a problem with the product, I'm configuring the rv110w to setup a VPN with the default settings and then i make users for both (QuickVPN and PPTP), when i make a vpn connection from a computer inside the network (with windows 7, just for test) this works, but when i try to make a connection from outside doesn't work, do i have to make simple port fordward 1723 to the router vpn server??.
and a second question, just OpenVPN works with this or i can use AnyConnect for android??, i need to setup the vpn connection in my android too.
Thanks!.
11-01-2013 05:13 AM
If my android device is the network using my wifi, can connect to VPN corectly but when i try to connect with 3G doesn't work, the same with my desktop PC
When i try to ping 10.0.0.1 (VPN Server Address) i dont get an answer.
This is the log file:
2013-11-01 09:00:25 RV110W daemon.err mDNSResponder: ERROR: getOptRdata - unknown opt 4
2013-11-01 09:00:41 RV110W daemon.err mDNSResponder: ERROR: getOptRdata - unknown opt 4
2013-11-01 09:03:19 RV110W daemon.err pptpd[1602]: CTRL: EOF or bad error reading ctrl packet length.
2013-11-01 09:03:19 RV110W daemon.err pptpd[1602]: CTRL: couldn\'t read packet header (exit)
2013-11-01 09:03:19 RV110W daemon.err pptpd[1602]: CTRL: CTRL read failed
2013-11-01 09:03:19 RV110W daemon.err pppd[1603]: no device specified and stdin is not a tty
2013-11-01 09:04:34 RV110W daemon.warning pppd[1713]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-01 09:04:35 RV110W daemon.warning pppd[1713]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
2013-11-01 09:04:47 RV110W daemon.err pptpd[1712]: CTRL: EOF or bad error reading ctrl packet length.
2013-11-01 09:04:47 RV110W daemon.err pptpd[1712]: CTRL: couldn\'t read packet header (exit)
2013-11-01 09:04:47 RV110W daemon.err pptpd[1712]: CTRL: CTRL read failed
2013-11-01 09:05:25 RV110W daemon.warning pppd[1816]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-01 09:05:25 RV110W daemon.warning pppd[1816]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
2013-11-01 09:05:34 RV110W daemon.err pptpd[1815]: CTRL: EOF or bad error reading ctrl packet length.
2013-11-01 09:05:34 RV110W daemon.err pptpd[1815]: CTRL: couldn\'t read packet header (exit)
2013-11-01 09:05:34 RV110W daemon.err pptpd[1815]: CTRL: CTRL read failed
2013-11-01 09:06:41 RV110W daemon.warning pppd[1938]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-01 09:07:11 RV110W daemon.warning pppd[1938]: LCP: timeout sending Config-Requests
2013-11-01 09:07:12 RV110W daemon.err pptpd[1937]: GRE: read(fd=14,buffer=451c4c,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
2013-11-01 09:07:12 RV110W daemon.err pptpd[1937]: CTRL: PTY read or GRE write failed (pty,gre)=(14,15)
Thanks!!
11-03-2013 11:09 AM
If i may ask, did you enable remote management for VPN?
11-03-2013 01:02 PM
Now i enable Remote Management.
But doesn't work.
This is the log only for VPN:
---> I connect VPN using my WIFI network. (This Works)
2013-11-03 17:34:26 RV110W daemon.warning pppd[6588]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-03 17:34:27 RV110W daemon.warning pppd[6588]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
---> Disconnect from VPN. (This messages are when i click in Disconnect option in VPN from Android)
2013-11-03 17:34:45 RV110W daemon.err pptpd[6587]: CTRL: EOF or bad error reading ctrl packet length.
2013-11-03 17:34:45 RV110W daemon.err pptpd[6587]: CTRL: couldn\'t read packet header (exit)
2013-11-03 17:34:45 RV110W daemon.err pptpd[6587]: CTRL: CTRL read failed
-->Try Connect VPN using 3G but does not connect. (Just disable WIFI in android and try to connect using 3G)
2013-11-03 17:35:57 RV110W daemon.warning pppd[6957]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-03 17:36:27 RV110W daemon.warning pppd[6957]: LCP: timeout sending Config-Requests
2013-11-03 17:36:27 RV110W daemon.err pptpd[6956]: GRE: read(fd=14,buffer=451c4c,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
2013-11-03 17:36:27 RV110W daemon.err pptpd[6956]: CTRL: PTY read or GRE write failed (pty,gre)=(14,15)
11-03-2013 04:25 PM
Adding more Logging options (Notif, Info) now i can see what is the problem.
-- > Connect using wifi to VPN.
2013-11-03 18:11:18 RV110W daemon.info pptpd[30661]: CTRL: Client 10.66.101.101 control connection started
2013-11-03 18:11:18 RV110W daemon.info pptpd[30661]: CTRL: Starting call (launching pppd, opening GRE)
2013-11-03 18:11:18 RV110W daemon.notice pppd[30664]: pppd 2.4.5 started by (unknown), uid 0
2013-11-03 18:11:18 RV110W daemon.info pppd[30664]: Using interface ppp0
2013-11-03 18:11:18 RV110W daemon.notice pppd[30664]: Connect: ppp0 <--> /dev/pts/0
2013-11-03 18:11:19 RV110W daemon.warning pppd[30664]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-03 18:11:19 RV110W daemon.warning pppd[30664]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
2013-11-03 18:11:19 RV110W daemon.notice pppd[30664]: MPPE 128-bit stateless compression enabled
2013-11-03 18:11:19 RV110W daemon.notice pppd[30664]: local IP address 10.0.0.1
2013-11-03 18:11:19 RV110W daemon.notice pppd[30664]: remote IP address 10.0.0.10
That was a normal connection with my Wifi.
--> Try connect using 3G.
2013-11-03 18:14:16 RV110W daemon.info pptpd[31411]: CTRL: Client 186.13.0.216 control connection started
2013-11-03 18:14:17 RV110W daemon.info pptpd[31411]: CTRL: Starting call (launching pppd, opening GRE)
2013-11-03 18:14:17 RV110W daemon.notice pppd[31416]: pppd 2.4.5 started by (unknown), uid 0
2013-11-03 18:14:17 RV110W daemon.info pppd[31416]: Using interface ppp0
2013-11-03 18:14:17 RV110W daemon.notice pppd[31416]: Connect: ppp0 <--> /dev/pts/0
2013-11-03 18:14:17 RV110W daemon.warning pppd[31416]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
2013-11-03 18:14:47 RV110W daemon.warning pppd[31416]: LCP: timeout sending Config-Requests
2013-11-03 18:14:47 RV110W daemon.notice pppd[31416]: Connection terminated.
2013-11-03 18:14:47 RV110W daemon.notice pppd[31416]: Modem hangup
2013-11-03 18:14:47 RV110W daemon.info pppd[31416]: Exit.
2013-11-03 18:14:47 RV110W daemon.err pptpd[31411]: GRE: read(fd=13,buffer=451c4c,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
2013-11-03 18:14:47 RV110W daemon.err pptpd[31411]: CTRL: PTY read or GRE write failed (pty,gre)=(13,14)
2013-11-03 18:14:47 RV110W daemon.info pptpd[31411]: CTRL: Client 186.13.0.216 control connection finished
That was using 3G, then i try with a different wifi network and it works.
I think that was the 3G connection because there is a time out in the service so i can't connect with 3G to VPN.
Thanks!!
