RV120W Administration Page The connection was reset
seantan921
I have a problem with RV120W, I can connect to internet and all, but I cannot get into administration page, once I input the username and password, it always comes back with.
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few
moments.
If you are unable to load any pages, check your computer's network
connection.
If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
That happens with Firefox and IE, any idea how to get it fixed?
rene00007
Hi Sean,
did you find another solution to access this router?
Thanks, René
Rene,
Please try Google Chrome browser and let us know if you are having issues.
- Marty
Hi Marty,
thanks for the answer, I found a solution myself. If you open the Webinterface with HTTPS ist works without problems.
René
Rene,
Thank you for posting the fix. I tend to do that without even thinking about it so I forget that it can solve the problem. I had the same issue with an ISA550 recently and using https solved it.
- Marty
