RV120W and 1.0.5.6
rmishra22
I am currently running Rv120W with 1.0.4.10.
I had multiple issues for which i had opened a ticket - 626369173 : [SRA 08/14]Esc
Earlier today I got the email that 1.0.5.6 is out which takes care of some of the issues. Since then i am trying to upload the new firmware into the rv120w but everytime after i press upload and after router tells me that it will reload, i loose my connection as its not returning back from his hing state and no ip is being allocated.
A manual reboot fixes the problem but the firmware stays at 1.0.4.10. I tried both wired and wireless connections but none worked. Then i saw this :-
Doesnt matter where i keep the firmware on PC, the path shown above is always same and from C drive. I am going to make a fakepath folder and try it from there but ....even after changing browsers, chrome, firefox or IE didnt help.
So i cant upgrade for now...anyone else with this issue ??
Zhaoqiang Wang
Hi, can you check the md5 value of the firmware? Should be:
653173364e1cf0f063efbe294335fe68
BTW, do you upgrade from a local LAN pc or from Internet PC?
Thanks for looking into this...the checksum is correct, here is the screenshot:
Yes, the firmware is correct. Then I suggest you open a case to let support team help you. We double checked upgrade locally and remotely, both are successful.
