01-13-2012 09:01 AM
I've a RV120W with the last firmware version (june 2011), i want to create two vpn tunnel:
- Professional: lan routing all packet for the 192.168.0.0/24 to the first VPN tunnel
- Other: all other address IP destination to a second VPN tunnel
The first tunnel (professional) is ok but what rules can i use to configure the second ?
Thank you
Ltn
01-13-2012 10:01 AM
Please clarify in detail what you're trying to accomplish. It would be helpful to have a simple topology including other routers and subnets.
Jasbryan
01-16-2012 07:13 AM
I want to have two tunnels:
- One to pass flows between my two networks 192.168.70.0 and 192.168.69.0
- A second to get the entirety of other flows in order to centralize the outputs to the Internet
I do not see what rule set up for my second tunnel
I realized a schema.
thank you
