08-22-2010 06:06 AM
I found that RV120W WAN interface doesn't automatically re-enable after a cable pull and re-plug. I have to go into the Status->System Summary and click the "Enable" button. Is this normal on this router? Can I prevent that from happening? I would hope this is NOT normal as this would mean that I would have to be on-site and login to the web interface to re-enable it after a power failure or WAN link loss.
09-23-2010 04:18 PM
Brandt,
Our developers are able to duplicate the issue now. We should see the issue fixed in the next firmware release, which is under testing now.
Thank you very much for providing the detailed information for us to quickly re-produce the issue in the labs.
09-23-2010 06:53 PM
Thanks tekliu and Brandt for following thru to resolution. I look forward to getting the updated firmware to keep my network going in the advent of an outage.
09-23-2010 07:15 PM
