I'm investigating an issue we have with video conferencing. I'm now at the UDP packet level and generated traces with the RV120W diagnostic tools to perhaps get a hint on our conferencing issue. When inspecting the trace, Wireshark reported that all incoming packages have a length error in the PPPoE frame.
I also looked at the same trace package with the MS Network tool. Both tools reported the same (short) length in the PPPoE header and also an equal and a much larger length in the payload, the UDP header (One packet analysis, displaying both lengths is attached).
Question: is this erroneous length a problem that would have consequences outside the router, for example for our conferencing system?
== edit running firmware v1.0.2.6
