11-11-2017 01:48 AM - edited 03-21-2019 10:58 AM
11-11-2017 06:02 PM
Tried to find on the data sheet but I only see ssl support for client VPN and VPN passthrough. Did not see S2S.
-If I helped you somehow, please, rate it as useful.-
11-12-2017 01:30 AM
*sigh* Flavio, the 130W absolutely does support IPsec with SSL certificates. It does NOT support SSL VPN" in a site-to-site configuration, but this is irrelevant to the question the OP asked.
To the original question, the 130W expects you to first upload the CA certificate, then generate a CSR. Then, download the CSR and sign it using your self-signed CA. Upload the resulting certificate to the 130W. You cannot create a cert/key pair outside of the device and import it; you must generate a CSR and then upload a signed certificate corresponding to the CSR generated.
