RV134W PQ Clarification
Stewart1
  • There is no reference to the term PQ, in relationship to QOS, in the RV134 administrator guide.  I assume PQ stands for Priority Queue.  The exact wording from the software screen is  "PQ's rate limit is not shared with Queue 1-4" .  I want to use the PQ QOS method for my voice VLAN, only 500kbits/s, yet I want to send this traffic as soon as possible - reduce latency.  Does PQ on the RV134W equate to the same function as the strict queue on the SRP527W, i.e, takes priority over all other queues?
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
I think it would be best if you could call our support line and open a support case.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Hi IIiya,
I will open a support case, yet the question is in relationship to PQ, it is not mentioned in the Administrator Guide, not that I can find anyway. My view is that, if a menu option is available for the Router, it should be covered in the Administrator Guide and not omitted with no explanation.
Thanks for getting back to me all the same and will follow your advice.
Kind Regards,
Stewart
