My Cisco RV220W (which has external antennas) router offer wireless coverage in every corner of my house. But my upload speed was limited to 1 Mbps (RV220W and ADSL2 modem bridge connection). The solution to the upload speed problem was to upgrade to a VDSL2 router. Therefore I decided to go with RV134W Cisco router, which doesn't have external antennas. Upload speed problem will be solved soon when the ISP will make all the necessary changes, but I ran into another issue. RV134W wireless signal is very weak in some rooms even in 2.4G mode.
Could an external antenna fix the issue with the wireless coverage? Which settings will help to increase the wireless coverage : WMM, U-APSD (WMM Power Save), Wireless Channel Width while still offering decent speed.
Firmware upgraded from RV134W-A-K9-NA to :
PID VID: |
RV134W-E-K9 V01 |
Current Firmware Version: |
1.0.0.29 |
This is RV220W with an option to set transmit power 30 dBm.
This option is not available for RV134W.
This are wireless specs of RV220W:
This are RV134W wireless specs:
My wireless settings:
