01-11-2020 01:28 AM
Hi There.
I am using RV160W since few days and i've got strange issues with 5Ghz radio. During the day it works as it should but over the night and morning it is not. I've started to watch pings and response from the Google and CludFlare DNS and few other addresses including ISP gateway is jumping around 1k-3k ms. At the same time using the same targets from 2.4Ghz and LAN cable I have got responses like 10ms - 14ms. I have separated SSID per radio and most of the configuration is set to default like QoS or advanced wireless settings. What is more i am not far away from router and I haven't got similar issues in the past with other hardware. I am the only one 5Ghz AP in my neighbourhood and there is no much visable 2.4Ghz networks outside my home. The number of connected devices is rather low. I would like to ask if someone of you face up such problems and what sort investigation i can conduct as i already did a lot...
01-11-2020 03:18 AM
01-11-2020 09:01 AM
why only that time, you need to note any other device connected ? or any other device interference taking place ?
01-11-2020 02:22 PM
I have no idea...Same sort of connected devices... at least in my network... no magic IoT stuff.. I just took that screenshot: I had to switch to 2.4GHz as 5GHz become useless..
01-12-2020 12:17 AM
Do you also see a performance that time, like slow browsing? is this ping latency go high also on Ethernet connected devices ?
did you try any other destination same time ? Local provider DNS IP ?
01-13-2020 11:10 AM
01-12-2020 08:25 AM
Today:
01-13-2020 02:09 PM
I have configured an additional AP ad located it next to Cisco router... on 5GHz it works as it should hence i would say there is no influence from other devices/noises... (..)
Is there someone who has this device and can share experience?
