RV180 Firewall Rule / Port Forwarding to internal Broadcast (WOL)
Franz Leu
Ho do I create a rule/port forwarding that is broadcasted to the LAN?
I tried to set 192.168.1.255 as destination IP (how I did and it worked with other router brands) but this is not accepted.
Franz
5 Replies 5
Franz Leu
Hmmm .... nobody an idea how this an be achieved?
Hi Franz, the router won't support a LAN broadcast over the WAN.
You can try to use a port forward for a specific host using the WOL port but I am suspecting you want to WOL more than just 1 host.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
.. but I am suspecting you want to WOL more than just 1 host.
That is exactly what we had before with Zyxel as well as with other brands and what I am trying to achieve with RV180 as well.
I am very surprised (or even disapointed) that this is not possible with this Cisco router.
Buying the more expensive device does not always seem to be the right choice
Where can I place feature request?
Hi Franz, to make a feature request, you would need a service request with the small business support center.
-Tom
