01-29-2013 09:15 AM
Hello from france,
sorry for my english
I have some troubles to whith my RV180
Port fowarding doesn't work properly
My routeur :
Nom d'hôte: | router0C62BC | Modifier | |
Version du firmware: | 1.0.1.9 | ||
Numéro de série: | SER161105MI |
I created a custom service:
Custom Services
Custom Service Table
Name | Type | ICMP Type / Port Range / Protocol Number | ||
N4100 | TCP | 8010 - 8010 | ||
I allowed port forwarding :
Port Forwarding
Add / Edit Port Forwarding Configuration | |||
Action: | |||
Schedule: | |||
Service: | |||
Source IP: | |||
Start: | (xxx.xxx.xxx.xxx) | ||
Finish: | (xxx.xxx.xxx.xxx) | ||
Destination IP: | (xxx.xxx.xxx.xxx) | ||
Internal Port: | (Range: 1 - 65535) |
And enabled it
Port Forwarding
Port Forwarding Rule Table
Action | Service | Status | Source IP | Destination IP | Internal Port | |||
Always Allow | N4100 | Enabled | Any | 192.168.0.5 | 8010 | |||
but i wasn't able to connect to my host 192.168.0.5 from WAN, it's works fine on the LAN.
So i tried to put my host's IP 192.168.0.5 as DMZ
DMZ Host
DMZ Host Configuration | ||
DMZ: | Enable | |
IP Address: | (xxx.xxx.xxx.xxx) |
But it still does not works.
This is the information i have in Debugging journal, but i don't know what to do whith it :
(i just clear my IPadress in blue)
Tue Jan 29 17:08:52 2013(GMT+0100) [rv180][Kernel][KERNEL] [ 5083.320000] WAN_LAN[ACCEPT]IN=ppp1 OUT=bdg1 SRC=XXX.XXX.XXX.XXX DST=192.168.0.5 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=61335 DF PROTO=TCP SPT=2943 DPT=8010 WINDOW=65535 RES=0x00 SYN URGP=0
Could Someone please help me ?
Solved! Go to Solution.
01-29-2013 11:07 AM
I have a similar problem, which seems to be a well known bug.
I also have several other problems regarding firewall rules.The RV180 is full of bugs.
Some people here have been expecting a 1.0.2.2 firmware which is supposed to correct those bugs but we are still waiting.
01-29-2013 12:17 PM
Hello Laurent,
Sounds like you are running into the port forwarding bug. Werid part about this issue is port forwarding works for some and not others. It could be with using PPPoE connection but not 100% sure on that. You could give Cisco support a call and they can get you in the direction to get a beta firmware to resolve the issue. I've started to see a couple people posting on the forums that the beta firmware is resolve the issue.
Cisc SBSC Numbers:
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Hope that helps!
Clayton Sill
01-29-2013 11:07 AM
01-29-2013 12:17 PM
Hello Laurent,
Cisc SBSC Numbers:
Hope that helps!
Clayton Sill
01-30-2013 01:45 AM
Hello Clayton,
Thank you for your help.
I just called cisco support , they opened a ticket they have escalated to level 2 to see if they could send me a beta firmware to solve the issue.
Best Regards
Laurent Esteban
