Site-to-Site VPN: Configure it between RV042 & Cisco 2911
KennedyD2010
Dear All,
Is there a way to set up a Site-to-site VPN between RV042 & Cisco 2911?
I "googled" this and obtained a document, but it is not regarding Cisco 2911:
http://www.tomshardware.com/forum/17552-42-connection-rv042-cisco-1760
Please, detailed steps for both Routers are needed to setup it successfully. I have tried on both routers several configuration steps, no success...
Best regards,
jonatrod
Level 7
Level 7
Good morning.
Thanks for using our forum.
My name is Johnnatan and I am part of the Small business Support community. You have  to set the RV042 to use the same (exactly the same) policies you are using with  your router 2911. Including DH group, encryption and authentication. I could help you with the RV042 configuration, follow these steps in order to configure it.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3011
If you need more help with your RV042, please let me know and I´ll help you.
This is small business section, you can have more feedback about your router 2911´s case posting a question in Security>VPN.
I hope you find this answer useful, *Please mark the question as Answered or rate the answer so other will know when an answer has been found.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Dear Sir,
Still unable to translate RV042 parameters to Cisco 2911 or viceversa.
I will appreciate some ligths on this,
Best regards,
Good afternoon.
Hi Daniel, my name is Johnnatan and I am part of the Small business Support community. Could you please send me some screenshots of your configuration? It would be very useful, be careful with the confidential data such password, and public addresses.
Greetings,
