RV180W - How to clone configuration
Starkj
We have a RV180W that is configured for the local network and three VPN Lan to Lan links.
I would like to buy another RV180W as a backup and set it to an identical configuration as the existing router.
Is it as simple as uploading the .cfg file taken from the live router?
Mark Malone
raluani
My name is Rozana and i am an engineer from the Small Business Team.
Yes you can save the startup configuration from the Administration tab > backup startup config,
then on the same page on the new RV180, restore the configuration to the startup and reboot.
Please make sure that you are using the same model (PID) of RVs and the same Firmware version, to avoid any issues that may occur.
