RV180W - problems on rules and port redirections
I installed a RV180W router a month ago.
Our production server has to retreive informations on a remote server so I set up the rules and port redirections accordingly on the firewall.
I noticed that some times the rules didn't work anymore and I had to reboot the RV to fix it.
The rules are still active on the router's admin panel as well as the services and the port redirection. The last firmware is installed.
Does anyone experienced the same problem and found a fix?
Thanks in advance,
Best regards
SamirD
Level 5
Level 5
I hate to say it, but there are issues like this with the rv series.  Have you replace the router with another one?  That's the first thing I would try since you can probably exchange it easily right now.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
