RV180W - wifi devices not connected ¡¡help!!
Good morning. I have recently RV180W router. Every day when I get to work I reset it so that it can connect wireless devices today are no longer connected. Always more than 100 errors appear in the log (attached screenshot). I have updated the firmware to version 1.0.3.10 ¡¡helps!!
jeffrrod
Level 4
Level 4
Dear Eduardo,
Thank you for reaching the Small Business Support Community.
We may be talking about a known issue, open caveat CSCug37953:
Description—The device does not forward HTTP responses when wireless clients move from an access
point's wireless to the router's wireless, if the access point is connected to a LAN port.
Workaround—Reboot the device.
If this is the case I then suggest you to open a service request with the Small Business Support Center in order to get a solution;
  https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
If the caveat description is not exactly what is happening, I suggest you to reset to factory conditions and reconfigure manually.
Please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Hi!!!
I've same problem, could you send me information about how to solve this?
Thank you
