RV200W drop connection so often recently
dragonflyteabar
Hi, I've had a RV200W Router for a few months (firmware 1.0.4.17)
Everything was smooth at the beginning but recently it keeps dropping PPPOE connection and wouldn't reconnect until I powercycle it.
I've done:
  • Reboot everyday
  • Set MTU to 1492
  • Turned off Auto Negotiation for WAN port
  • Turned off all attack preventions
  • Turned off SNMP
  • Turned off Bonjour & UPnP
Here is the Warning Log:
Thu Oct 10 15:50:21 2013(PDT) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Thu Oct 10 15:56:06 2013(PDT) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Thu Oct 10 15:58:46 2013(PDT) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Error Log:
Thu Oct 10 15:49:54 2013(PDT) [rv220w][System][FIREWALL] fwPPTPGenericRules.c: inet_aton failed
Thu Oct 10 15:49:55 2013(PDT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Thu Oct 10 15:50:19 2013(PDT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 5 failed. status=-1
Thu Oct 10 15:50:19 2013(PDT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=5
Thu Oct 10 15:50:51 2013(PDT) [rv220w][System][FIREWALL] fwPPTPGenericRules.c: inet_aton failed
Thu Oct 10 15:56:06 2013(PDT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 6 failed. status=-1
Thu Oct 10 15:56:06 2013(PDT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=6
Thu Oct 10 15:57:07 2013(PDT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 5 failed. status=-1
Thu Oct 10 15:57:07 2013(PDT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=5
Thu Oct 10 15:58:46 2013(PDT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 7 failed. status=-1
Thu Oct 10 15:58:46 2013(PDT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=7
Anything I should to have it at least reconnect after a pppoe drop?
Kremena Ivanova
Try changing the Connection type from Keep Connected to Idle Time
Kremena
