RV215W and DHCP Options
Khan Hollis
I've been searching the documentation plus used search engines to see if anyone else has asked or written about the Cisco Small Business RV215W multifunction routers support the use of DHCP options?  We'd like to use DHCP on the device to pass data such as NTP or information for our ShortTel phones.
Is that possible to do this with this router when local devices on the internal network (at the remote location) obtain information with DHCP?
cchamorr
Level 5
Level 5
The RV215W is not capable of providing any DHCP options.
The RV320 on the other hand has the capability of configuring a few options like a TFTP server and such.
Here is a link to the admin guide for the RV320, page 46 talks about DHCP setup and options supported
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/rv32x_ag_en.pdf
Below you will also find a emulator for the RV320 that will show you all the options on the device
https://www.cisco.com/assets/sol/sb/RV320_Emulators/RV320_Emulator_v1.1.0.09/default.htm
I hope this helps
