RV220W and UPS WorldShip
Fireman1224
I'm having problems getting UPS WorldShip to connect. The program says I need to allow incoming UDP on Port 1434. I set a service to allow this, but it still doesn't connect. Any ideas on how to configure this?
Thanks in advance!
jeffrrod
Level 4
Level 4
Dear Dwight,
Thank you for reaching the Small Business Support Community.
If you disable the router's firewall, are you able to connect? If so, you must check on the allow/deny rules you have entered. Something you may try is to "add a trusted domain" (check on admin guide, page 92),
http://www.cisco.com/en/US/docs/routers/csbr/rv220w/administration/guide/rv220w_admin_v1.0.1.0.pdf
I hope you have already been through out the Worldship system requirements, if not please do.
Please do not hesitate to reach me back if anything comes up and/or if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
