08-14-2011 05:39 AM
Hey, recently got a RV220W and liking all the configuration options.
Although I cannot find where to change the listening port for management? I want it to listen on port 81 instead of 80. It has to be in here somewhere, anyone have an idea?
Cheers,
Michael
08-14-2011 02:37 PM
08-14-2011 08:00 PM
I found that, but I do not want remote management. I want to change the local management port, nearly every router I have known in the past 5 years can do this...
08-14-2011 10:33 PM
May I know what the use case for changing the port for local administration is? As far as I know, none of Cisco Small Business routers support this option.
08-15-2011 02:36 AM
I have a local media server that is on port 80 and use a common URL to access it from within/outside my network. So whenever I use the URL within my network, it always resolves to the router. Being able to change the local management port (to 81) will enable people to not have to worry about running services that require themselves to be on port 80.
My old router I have upgraded from could do this and it's a feature I would expect to be on nearly every router these days.
08-15-2011 07:53 AM
why do you need to change the port address of the Router for WebGUI access?
https://
if you know your Media Server IP address, then type that in your browser and see if it works.
