RV220W DNS proxy trouble
Jens Janssen
My problem: sometimes (serveral times a day) domain name resolution doesn't work. The destination is not reachable. Pressing refresh button several times helps.
My idea: Hey lets disable DNS proxy and see what happens. No sooner said than done - but the next problem:
If DNS proxy is disabled name resolution won't work at all. 192.168.1.1 still shows up as DNS server address. Any Ideas?
maloitpro86
I have identical issue, see:
http://supportforums.cisco.com/message/3451566
My issue is exactly the same as yours, exept that Local DNS name resolution doens't work at all with DNS proxy enabled.
Disable DNS proxy, and now WAN DNS doesn't work...
I will monitor this thread for a solution as well.
SAM
