05-07-2012 12:30 PM
I am trying to have the RV220W router auto-update the dyndns registration.
The dynamic domain that I use is .info -- note the .info domain.
When I manually update the dyndns information (username and password) the registration does go through and the entry is updated on the dyndns site.
However, the registration does not auto-update after that.
Any ideas why this might be happening?
Alex
05-07-2012 03:10 PM
I believe this is a known issue. You might perform a search. At any rate, I'd call Tech Support and open a ticket. The more information you have to offer, the better chance they have to reproduce the issue so it can get resolved. It also seems as though the bugs that are bugging (pun intended) folks the most get the most attention.
07-05-2012 07:50 AM
I have the same problem on the RV220W with a .org domain from DynDNS, using the latest firmware, 1.0.3.5. It will update manually, and on a reboot of the router, but does not update automatically. I've tried several setting or the update persiod, and it did not make a difference. Is there any word on a fix for this?
07-05-2012 12:23 PM
The DDNS auto-update issue has been fixed with firmware 1.0.4.15, which is still under testing.
08-24-2012 02:45 PM
Firmware 1.0.4.17 has been released, but the release notes do not show any fixes for this issue. Was it not resolved?
08-25-2012 03:30 PM
It is probably an omission. The fixes in 1.0.4.15 are carried over to 1.0.4.17 by default.
08-26-2012 08:46 AM
Based upon another user's experience, the UPnP *fix* seems to have been lost in 1.0.4.17 as well.
