Rv220w port forwarding dvr
jeff reynolds
I have a dvr that uses RasPlus app to connect to dvr remotely. The netgear router allowed me to portforward to both tcp and udp to the dvrs lan address. I'm not finding this option in rv220w. Thanks! I just need to allow rasplus app to access dvr at address 192.168.1.150 on port 8016.
mdobiac
Level 3
Level 3
Hello jeff reynolds,
First I would update to the latest firmware on the RV220W.  The latest is 1.0.6.6:
Here is the link:  https://software.cisco.com/download/release.html?mdfid=283118607&softwareid=282487380&release=1.0.6.6&relind=AVAILABLE&rellifecycle=&reltype=latest
After that you will go under Firewall > Port forwarding.  You will create your rule there.  However you many need to make a custom service.
To create a custom service:   Firewall > Advanced Settings > Custom Services page, click Add
Put in the necessary information then create your port forwarding rule.
Hope this help,
Michael D.
