07-07-2012 10:24 PM
I'm having problems with a port forward to an apache server on my lan. I created the port forward in the same way as an ssh forward, and it works fine.
07-07-2012 11:34 PM
Hello Doug,
When creating the portforwarding, are you using the default rules within the router?
Please try to create a custom service (even if the service already exists within the drop down....) then use the IPV4 firewall rules page to attempt the port forwarding.
Example;
Untrusted zone (wan)
Trusted zone (lan)
Service = (custom service you created!)
Always allow
Source host - ANY
Send to local server (DNAT) - xxx.xxx.xxx.xxx
Dedicated WAN
Save the configuration
07-07-2012 11:51 PM
Hi Thomas,
Both of my port forwards were created as custom rules, and then added as forwarding rules. See attached .txt file. The ssh rule works like a charm, but the tcp port 8080 apache rule doesn't.
07-27-2012 06:31 PM
Hi Doug, if you'd like to work on this issue, we at the SBSC will be more than happy to try to assist you any time, we are open 24/7.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
-Tom
07-27-2012 06:00 PM
business class router my A$$.
