RV220W random Reboots
rs
Hi,I started getting issues where the above router start rebooting at random times. i have not been able to find explanation. From the logs the following is reported, - can anyone determine from this what the problem is:
Mon Apr 18 21:21:23 2011(UTC) [rv220w][System][PLATFORM] ../../mgmt/8021xMgmt.c:DBUpdate event: Table: _8021x opCode:18 rowId:1
Mon Apr 18 21:21:23 2011(UTC) [rv220w][System][PLATFORM] profile default doesnt exist.
Mon Apr 18 21:21:23 2011(UTC) [rv220w][System][PLATFORM] Deletion of EAP Profile failed
Mon Apr 18 21:21:28 2011(UTC) [rv220w][System][PLATFORM] IPv6 not configured on the interface
Mon Apr 18 21:21:28 2011(UTC) [rv220w][System][PLATFORM] RADVD stopped successfully
Mon Apr 18 21:21:30 2011(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 1 failed. status=-1
Mon Apr 18 21:21:30 2011(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
Mon Apr 18 21:21:31 2011(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 1 failed. status=-1
Mon Apr 18 21:21:31 2011(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
Mon Apr 18 21:21:31 2011(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 1 failed. status=-1
Mon Apr 18 21:21:47 2011(UTC) [rv220w][System][PLATFORM] dnsResolverConfigure: addressFamily: 10
Mon Apr 18 21:21:47 2011(UTC) [rv220w][System][PLATFORM] dnsResolverConfigure: LogicalIfName: WAN1
Mon Apr 18 21:21:47 2011(UTC) [rv220w][System][PLATFORM] dnsResolverConfigure: addressFamily: 2
Mon Apr 18 21:21:47 2011(UTC) [rv220w][System][PLATFORM] dnsResolverConfigure: LogicalIfName: WAN2
Mon Apr 18 21:21:57 2011(UTC) [rv220w][System][PLATFORM] igmpEnable: IGMP proxy enabled successfully
Mon Apr 18 21:21:58 2011(UTC) [rv220w][System][PLATFORM] dbRecordValueGet failed for ProfileName column
Mon Apr 18 21:21:58 2011(UTC) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Mon Apr 18 21:21:59 2011(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 2 failed. status=-1
Mon Apr 18 21:21:59 2011(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=2
Mon Apr 18 21:21:23 2011(UTC) [rv220w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PHY_PORT_DECONFIG(33)
Mon Apr 18 21:21:23 2011(UTC) [rv220w][Local0-wireless][PNAC_USR] Error from pnacPhyPortDestroy: port not configured
Mon Apr 18 21:21:23 2011(UTC) [rv220w][Local0-wireless][PNAC_USR] pnacUmiPhyPortDestroy: Failed to destroy the port
Mon Apr 18 21:21:23 2011(UTC) [rv220w][Local0-wireless][UDOT11] DBUpdate event: Table: dot11Interface opCode:23 rowId:1
Mon Apr 18 21:21:24 2011(UTC) [rv220w][Local0-wireless][UDOT11] DBUpdate event: Table: dot11Interface opCode:23 rowId:2
2000-01-01 00:00:37: [rv220w][IKE] INFO:  IKE started
The router is running the latest firmware.
Petrbenda
I used to have the same issue. At first, I called the Cisco´s support. They disabled “Block Multicast Packets“ (Firewall, Attack Prevention …) and the amount of random reboots decreased immediately by 90%. Since that time It had rebooted a few times per day only. I had started disabling other functions at this part. Since I disabled the last function, except of “Respond to Ping on WAN (Internet)“ I have been without those random reboots.
9 Replies 9
Te-Kai Liu
Level 7
Level 7
How often did random reboot occur, once every few days?
Could you enumerate the devices that connect with the RV220W?
Sure,
I have 2 notebooks connecting over wireless,
One workstation connected with cable
And a few mobile phones connecting over wireless.
A printer over wireless.
A QNAP 239 pro NAS
The reboot basicly happens once a day.
What about the connectivity on the WAN port of the RV220W?
Its connected to a comega ftth cpe gateway, more details can be found here.
http://www.dkt.dk/Default.aspx?ID=32&M=Shop&PID=161&ProductID=72
Rolf, would you consider calling the Support Center so someone can work with you on further troubleshooting the issue?
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Sure, will i need addionel info before calling. Anything that should collect to have ready?
Most likely the case will be escalated to level 2 support so things like router config file and debug log can be collected.
Yea explains why i have not had those problems for a long time, - i reset my router at one point after all this trouble, - i also recall that i unchecked “Block Multicast Packets“ option... Thanks for replying Petr...
Petrbenda
