VPN Tunnel issues with RV120W logs
gwhitten
I have setup a Client with a RV120W to have access to a IBM System i server. The connection will stay up for a while and then fail. I am unable to "DROP" the connection and reconnect. I have to disable the VPN tunnel and then do an edit process even though I don't actually change anything. I enable the tunnel and then I can connect the VPN tunnel again. I do not have access the Cisco ASA that it it connects with so I cannot give the settings for it. I suspect there is not a problem with the ASA configuration as it does work but will not stay connected. Below is the configuration information for the RV120W.
System Information
Host Name : routerBBE424
Firmware Version : 1.0.4.10
Firmware MD5 Checksum : bbe601c388c75979368523e575c6b8b3 PID VID : RV120W-A V01
LAN (Local Network) Information
MAC Address : F0:F7:55:BB:E4:24
IPv4 Address : 192.168.96.2 / 255.255.255.0
IPv6 Address :
DHCP Server : Enabled
DHCP Relay : Disabled
DHCPv6 Server : IPv6 is disabled
WAN (Internet) Information
WAN (Internet) Information (IPv4)
MAC Address : F0:F7:55:BB:E4:25
Connection Time : 0 Days 12:59:04
Connection Type : Static
Connection State : Connected
IP Address : 10.0.0.3
Subnet Mask : 255.255.255.0
Gateway : 10.0.0.2
Primary DNS Server : 10.0.0.2
Secondary DNS Server : 66.175.131.21
NAT (IPv4 Only Mode) : Enabled
WAN (Internet) Information (IPv6)
Connection Time : Not Yet Available
Connection Type : DHCP
Connection State : Not Connected
IP Address : fe80::f2f7:55ff:febb:e425/64 Gateway :
DNS Servers :
Wireless Information
Operating Frequency : 2.4GHz
Wireless Network Mode : B/G/N-Mixed
Channel : 1
VPN settings from configuration with remote site X out.
IpsecIKEPolicy = {}
IpsecIKEPolicy[1] = {}
IpsecIKEPolicy[1]["Direction"] = "0"
IpsecIKEPolicy[1]["EncryptionAlgorithm"] = "2"
IpsecIKEPolicy[1]["LocalIdentifier"] = "10.0.0.3"
IpsecIKEPolicy[1]["ExchangeMode"] = "0"
IpsecIKEPolicy[1]["RemoteIdentifier"] = "66.175.xxx.xx"
IpsecIKEPolicy[1]["Presharedkey"] = "09B9344D39D54F9CD6D9*"
IpsecIKEPolicy[1]["IKEPolicyName"] = "Choctaw_CH"
IpsecIKEPolicy[1]["LocalIdentifierType"] = "0"
IpsecIKEPolicy[1]["SALifeTime"] = "86400"
IpsecIKEPolicy[1]["DPDDetectionPeriod"] = "15"
IpsecIKEPolicy[1]["ModeConfigStatus"] = "0"
IpsecIKEPolicy[1]["XAUTHType"] = "0"
IpsecIKEPolicy[1]["DPDFailureCount"] = "4"
IpsecIKEPolicy[1]["AuthAlgorithm"] = "2"
IpsecIKEPolicy[1]["AuthType"] = "0"
IpsecIKEPolicy[1]["DHGroup"] = "2"
IpsecIKEPolicy[1]["DPD"] = "1"
IpsecIKEPolicy[1]["_ROWID_"] = "1"
IpsecIKEPolicy[1]["RemoteIdentifierType"] = "0"
IpsecVPNPolicy[1] = {}
IpsecVPNPolicy[1]["EnableKeepAlive"] = "0"
IpsecVPNPolicy[1]["LocalSubnetMask"] = "255.255.255.0"
IpsecVPNPolicy[1]["EncryptionAlgorithm"] = "2"
IpsecVPNPolicy[1]["AuthAlgorithm"] = "2"
IpsecVPNPolicy[1]["RemoteNetworkType"] = "3"
IpsecVPNPolicy[1]["AutoPolicyType"] = "0"
IpsecVPNPolicy[1]["LocalGateway"] = "0"
IpsecVPNPolicy[1]["RVGStatus"] = "0"
IpsecVPNPolicy[1]["VPNPolicyName"] = "Choctaw_CH"
IpsecVPNPolicy[1]["LocalStartAddress"] = "192.168.96.0"
IpsecVPNPolicy[1]["Status"] = "1"
IpsecVPNPolicy[1]["Netbios"] = "0"
IpsecVPNPolicy[1]["KeepAlivePeriod"] = "10"
IpsecVPNPolicy[1]["PFSKeyGroup"] = "0"
IpsecVPNPolicy[1]["RemoteStartAddress"] = "10.6.1.0"
IpsecVPNPolicy[1]["IKEPolicyName"] = "Choctaw_CH"
IpsecVPNPolicy[1]["SPIOut"] = "0x"
IpsecVPNPolicy[1]["KeepAliveFailureCount"] = "3"
IpsecVPNPolicy[1]["LocalNetworkType"] = "3"
IpsecVPNPolicy[1]["SALifeTime"] = "4608000"
IpsecVPNPolicy[1]["RemoteSubnetMask"] = "255.255.255.0"
IpsecVPNPolicy[1]["PolicyType"] = "1"
IpsecVPNPolicy[1]["RemoteEndPoint"] = "66.175.xxx.xx"
IpsecVPNPolicy[1]["NodeId"] = "1"
IpsecVPNPolicy[1]["SALifeTimeType"] = "1"
IpsecVPNPolicy[1]["Rollover"] = "0"
IpsecVPNPolicy[1]["SPIIn"] = "0x"
IpsecVPNPolicy[1]["RemoteEndPointType"] = "0"
IpsecVPNPolicy[1]["_ROWID_"] = "1"
IpsecVPNPolicy[1]["FailbackTime"] = "30"
Receiving the following messages as well but not sure why. Any suggesstions to resolve?
[rv120w][Kernel][KERNEL] printk: 3 messages suppressed.
[rv120w]Tue Dec 11 11:48:37 2012(CST)
[rv120w][Kernel][KERNEL] cvm_ipfwd_cache_flow: Failed to allocate flow info buffer
[rv120w]Tue Dec 11 11:49:32 2012(CST)
[rv120w]Tue Dec 11 11:53:12 2012(CST)
[rv120w]Tue Dec 11 11:58:12 2012(CST)
gwhitten
Does anyone have any suggestions regarding the log messages?
