RV220W Reboorting daily
tdraaisma
Does somebody recognize this problem ?
I have a RV220W setup with SSL VPN users, authenticating to an internal Active Directory. Maybe 5 ports forwarded and 8 external IP addresses. Besides this i have 1 data VLAN and a voice vlan on my network.
The reboots are on different times on a day, even on Sundays at 7 AM when noone is logged in to the network.
FW is at 1.0.4.17
Anybody familiar with these issues ? It's getting very very annoying.
Tom Watts
Hi Tristan, I've heard similar problems, a lot of the time, when folks upgrade to 1.0.4.17, they don't reset the router to factory default. This firmware upgrade was a major upgrade and seems to have some code overlap to the older firmwares.
If you can take the time to reset that unit and give a manual config, I think it will work ok.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
